power IR support
Beantworteti just got a NAD M10 and am using the android blueOS app's IR learning function to program my harmony remote. this works well, except... there is no power command in IR learning? i don't even quite understand why this command is missing and it's driving me crazy since i now am back to having to find the M10 remote to power it on and off every time. please add power commands to IR learning?
Hi Mike
Like all Internet/Smart technologies - your NAD M10 is designed to be always on and always ready. After 15 minutes of idle, the amplifier does shut down into a low power mode consuming less than 3w. This is required by EU Law.
The NAD M10 is much like other smart devices - if you fully power it down, it may take as long as 3-5 minutes to fully boot and not all services may be ready when you are.
Our recommendation is just to leave it on.
@Tony W.
Give us than this Stand by option so we can put out device to Stand by with a press of a button instead of waiting 15 min to go to Auto stand by.
Deniel.
2
