Node 2021 wifi and ethernet
BeantwortetHello!
My config is wifi. This morning, I connected RJ 45 network port.
All seems OK, by how do know node is connected with this port?
Wifi is automatically disconnected?
Hi Michael
If the link light is on on the back of the Player you are connected via Ethernet. In Help, Diagnostics of the BluOS App, the WiFi signal strength indicator will not appear. Bluesound Players are not multi-homed devices. If the Ethernet Port is Active, the Wi-Fi port shuts down. FOr more details, please see www.bluesound.com/network101
Thanks.
The wifi signal not appear: right in the BluOSApp.
The link light is on on the back of the Player: sorry, no link light exist on the back of the player (last node).
On the back of my box, the link light exist and flash when I use the player.
So, sur I'm connected via ethernet3.1
