    Mark T.
    Sr. Support Crew Member
    Hi Jelger,
    There is no direct way to connect the turntable to POWERNODE1. One workaround that can work is by using a Bluetooth adapter to connect the turntable to the POWERNODE.
  • Jelger de Kroon
    Thanks Mark for your quick response. Probably will give it a try but it will not give the best sound quality.
