NODE USB Connection
BeantwortetI would like to know if I can connect Node via USB cable from my computer directly or the only way to send audio signals from the computer (Macbook) to Node is via wireless only? Thanks and regards!
Hi,
The USB port for the Bluesound NODE is only meant to be used for USB Audio out and for USB mass storage. It is not meant to connect audio signals from your Macbook. You can use your Macbook's Bluetooth to send audio to the NODE or create your local library and control your NODE using our BluOS app.
How do I connect music on my NAS, PC or iTunes Shared Music to Bluesound? – The Bluesound Support Crew
