NAD C700 not available for fix groups (with Flex 2i)
    Mark T.
    Sr. Support Crew Member
    Hi,
    Please send a support request using the BluOS app for us to review your diagnostic log file/s.
    BluOS app >> Help >> Send Support request.
  • chris S
    Hi Mark,
    Ok, I did that. Thanks.
  • chris S
    A short feedback on this: First the support could not verify the problem, bzt after some back and forth it turned out, that it works fine on BluOS (which the support crew used), but not on Android. So this is confirmed: no NAD C700 available when trying to create fixed groups on Android. However, once you do the setup on iOS the fixed group with the NAD is also available on Android and it works
    It is unclear when this will be fixed.
