230 volt power
Will the Node and Vault work on 230 volt power?
The units came with both plug types: 110 and 230 Asian wall plug.
Do I need a transformer from 110 v to 230?
thanks, Kevin
Power rating: 100-240V~50/60Hz
Thank you!
Kevin
Does this mean i can use same node and/or powernode both in usa and europe?
