Powernode 2i -- confusion about Subwoofer low-pass setting when using "on/off" switch
6 Kommentare
    spellyny
    Just to close the loop on this, and for the benefit of the community, I have been informed by tech support that my instincts are correct.  The sub output is always on, but the x-over point DOES NOT remain constant as set by the user, despite all the comments on this board to the contrary.  The sub crossover defaults to 80Hz when the toggle is switched to OFF.  When toggled ON, the user selected x-over is what determines the low-pass at the SW output.  This is EXACTLY what I am experiencing in my system.
  • Mark T.
    Sr. Support Crew Member
    Hi,
    I have escalated this as a support request to our support crew to investigate further.
    A member of our support team will be reaching out to you soon to gather some additional information and work towards a solution with you.
  • nstzya
    Thanks @spellyny. As I’ve written elsewhere, I do not understand the purpose of this software algorithm - in what scenario would you want the processing and output to remain active with Sub Off? IMO, it would be much more useful for sub setup (level/phase/location/etc) to be able to turn sub output off when Sub Off is chosen.
  • spellyny
    It seems the main intent of the ON/OFF switch is for the user to apply (or not)  a high-pass filter at the analog outputs for your main speakers.  In practise, that's what it does.  It also determines what low-pass is applied at the SUBW OUTPUT:  user selected X-OVER when ON, default 80Hz when OFF.
    But as you correctly state, SUBW OUTPUT is always active even when SUBWOOFER is switched to OFF.  The power switch on subwoofer itself will need to be used to power it on / off when setting up and locating it.
  • nstzya
    I rather be able to turn the sub on and off from my listening chair. I don’t understand why it defaults to 80Hz when Sub is OFF
  • spellyny
    Just a guess, but I figure the logic is that 80Hz is a reasonable level to low-pass a sub when it's just  supplementing the bottom of most speakers out there (ie: small and medium sized) when they are being run full range (ie: OFF position).    When high-passing main speakers (ie: ON position), the Node gives flexibility that allows user to select CROSSOVER as a function of speaker size, and therefore LF reach.
