Node Icon with external DAC to main speakers and internal DAC for subwoofer
    Mark T.
    Sr. Support Crew Member
    Hi Mahesh,
    You can connect your NODE ICON to your external DAC via coaxial and your subwoofer to the NODES's SUB OUT.
    In the BluOS app, go to Settings > Audio, enable Subwoofer, and set the crossover to 100 Hz.
    You can try these settings and let your ears decide what sounds best for your setup.
    Thanks for #LivingHiFi
  • Mahesh Krishnaswamy
    I assume digital passthrough should be disabled but the output level can be fixed, since I plan to use my pre-amp to control the volume and to adjust the sub volume by ear only if needed.
  • Lucacelli
    Unfortunately not. If you want to control volume from your DAC sub has to be connect to your DAC cause NODE is in volume fixed mode.
