problems with SUB
5 Kommentare
    Hi Villiam
    Please see; https://support1.bluesound.com/hc/en-us/articles/360056643913
    The PULSE SUB+ can only be paired with the NAD M33 using a traditional sub-woofer cable.
  • Viliam Majer
    I write about it.
    I have M33 connected via CINCH RCA.
    If it is connected in this way and I turn off M33 and I want to listen only to soundbar + sub, then in the application it will say that SUB "analog connection"
    Real disaster
  • Viliam Majer
    no sound after.
    If you are trying to connect the SUB+ to a SOUNDBAR wirelessly and the NAD M33 via sub connection, this is not possible. You can only connect the SUB to one device at a time, regardless of the connection method.
  • Viliam Majer
    So this is a disaster.
    I'm not going to get rid of it sooner.
    Very wrong purchase decision.
