Using both HDMI ARC and Optical
    You can connect both TVs, but if you have AutoSense enabled under Settings, Player, Customise Sources... if both TVs are on the HDMI TV will hog the output (same for the Optical if you have Optical AutoSense enabled but HDMI  AutoSense off).
    You will have to disable both AutoSense options and manually switch in the BluOS App for the desired source...
  • Brett Raymond
    Thanks, That's exactly what I needed to know.
