Node 2i - I can either be connected via ethernet or WIFI, not both at the same time.
    Check your router or firewall documentation - Either your router or more likely Windows is not allowing for SMB Protocols (Windows File Sharing) over a wireless connection.
    Please see; https://support.bluos.net/hc/en-us/articles/360000186887to check your Windows settings...
