6 Kommentare
  • mike thompson
    I want to use the Dac on the Node. Do I just go from the Node audio out and plug into audio in on my denon 3700
    -1
  • mike thompson
    Can I just use regular RCA cables red and white
  • mike thompson
    Great! Thanks for the help.
    I'm going to use this with roon and tidal MQA
    plus I bought some Flac 192kHz 24 bit files off of Qobuz
  • mike thompson
    I just use a old Mac mini but i do agree the license is really expensive
  • Kandiah Kanagandram
    Wonder if I can piggyback another question on this thread..? I have the same set up as the OP where the Node 3 is connected to DENON 3700 via RCA Left and Right Audio connections. The follow up connection is the which sound mode of the Denon Amp  should be set to in order to stay true to the source  ..?  The various sound modes are
    1. Various modes of Dolby ATMOS, Dolby DIgital Plus etc  OR
    2. Multi Channel Stereo  OR
    3. Direct or Pure Direct ?
    Thanks
    Kandiah
    https://manuals.denon.com/AVRX3700H/NA/EN/DRDZSYyrtgycpw.php
  • Jonathan Paul Blythe
    Can I piggy back here? I've just bought node x to stream to my denon avr-x2800h. I've connected with rca cables in aux 1 on the denon. My question is, in the input assign menu, should I use digital or analogue option? I know there's an auto setting, but I don't think that's 100% reliable
