Fritz NAS no connection
14 Kommentare
    Bjørn Ulvik
    Using the mediaserver feature in your Fritzbox will not work.
    You will have to figure out how, or if you can connect to the internal storage.
    If you look in Windows Explorer and network, is the share visible there? If so, you will find your share/sharename there.
  • Norbert Pfleger
    Thank you for fast response
    The path above is that, shown in win explorer - Network (paste & copy)
    \\fritz.box\FRITZ.NAS\ST6000VN-001-2BB186-01\Musik\CD\Div Interpreten
    The NAS Storage can be accessed by Win Explorer, VLC Player win + android
    Name and PW i tried for each Fritzbox user
  • Bjørn Ulvik
    Could you try this if:
  • Norbert Pfleger
    sorry
    Mounting share failed (like before)
  • Bjørn Ulvik
    failed because it's not finding the share, or because of wrong credentials.
    if you copy/paste this (\\fritz.box\FRITZ.NAS\ST6000VN-001-2BB186-01\) in windows explorer address bar, what happens then?
  • Norbert Pfleger
    @Bjorn
    The folder get opened, full access
    @ Seppi Evans .. thank you for response ..iam really frustrated
    \\fritz.nas ... \fritz.nas ... \\fritz.nas
    URL wie folgt eingeben (like URL wrong style)
    \\FRITZ.NAS\fritz.nas\ with admin user+PW
    Is it a better way to  install an raspy with kodi as NAS ?
  • Norbert Pfleger
    it seames to work :)
    indexierung seames to run
    if it works, you have earned more than one beer :)
    thanks for helping
  • Stefan Wimmer
    @seppi Thanks so much. This was driving me nuts - tried every single combination to no avail. You saved my day!
  • Ralf F.
    I have the same problem but the way Seppi did it doesn't work.
    I have plugged a USB stick as NAS into my Fritzbox 6591, set a new user and password.
    But when entering the path the way Seppi did, I cant get the connection.
    I tried several ways, also the complete path to the folder where the music files are, but cant get connecetd.
    What am I doing wrong?
  • Ralf F.
    Yes, the NAS function is turned on.
    I also created a new user with new user password.
    But maybe the path ist set wrong? I tried several ways, to point directly to the specific music folder on the USB stick and also just \\FRITZ.NAS\fritz.nas\. Also tried this with the IP instead of the name.
    Nothing works. :(
    Do you set the path directly to the folder where your music files are or just to the NAS?
  • Ralf F.
    Doesn't work.
    I just tried to point via local shares to a folder directly to my PC. That works.
    But using network shares, entering the path you told me or directly to the stick doesn't work.
    Sorry, don't know how to connect my PC. What user do I need to enter?
    Tried but entering my Windows username and password it doesn't work.
  • Ralf F.
    To connect my PC I type like this: \
    \Computername\C:\folder
    Then enter as user the user I created at the Fritzbox (who has only access to all storage connected to the Fritzbox)
    Then the password.
    Doesn't work.
  • Peter Pfeifer
    Thank you, Seppi Evans.
    \\192.168.178.1\fritz.nas
    works beautifully! (after making sure all Fritz!Box settings are correct)
    Best wishes
  • Jörg Higli
    Years ago, I also tried to connect the FRITZ.NAS to the Bluesound Node. Didn't work then, but works now. Anyway, since the USB-Ports at Fritz are pretty underwhelming, I found another solution which works way better than FRITZ.NAS:
    I needed a switch to expand my LAN and I had an old Linksys MR7350 router in the drawer. Turned off the Wifi on the Linksys and installed it as my new network switch. The best part is, the Linksys has a full fledged USB3 port and SMB2 support. Put on my music HDD for the Node and now I have the full 110 MB/s read/write speed from my Windows computer. The MR7350 (or similar devices) is easily available on ebay for little money. Try it!
