Grounding of speaker cables for Powernode?
    Bjørn Ulvik
    Speaker cables goes to.....speakers, not to "ground"
  • Peter Petersson
    Its true that speaker cables goes to the speakers. However, the speaker cables also have a ground cable that usually connects to a grounding on the amplifier. But I couldnt find any such connection on the Powernode. Has anyone any ideas for this?
    Speaker grounding cables are generally not required. If you are having an issue and are hearing a ground loop it speaks more to the amplifier. If you are hearing this problem please select Help Send Support Request and we will be happy to troubleshoot. We generally have not seen this happen though.
