couldn't load settings
9 Kommentare
  • Timon Van Helden
    I had the exact same problem. Couldn't find the player and no player popped up after restarting. So I have to add a new player. Now I'm not getting past the 'change WiFi to the hotspot' screen. Did make my phone forget the first Node Network, restarted again... restarterd my phone.. nothing... Changed WiFi - network (i have several).. no luck and worse.. no music!
    Very frustrating
  • Alain DW
    Lossless
    Did you, as suggested by Seppi, reboot the router and follow the rest of the procedure?
    If that did not work, connecting the device directly to the router with an ethernet cable should help setting up the configuration.
  • Timon Van Helden
    I did reset the whole lot.. router, Node, iPhone...
    Tried connecting to the router aswell.
  • Alain DW
    Lossless
    Best send an email with details about your setup to support (blue button on the lower right on this page).
  • Rays Jazz
    I'm got this issue as well now. Just playing some music and it stopped. Can't see anything, couldn't load settings, message. Tried powering off and on as above but nothing. The blue light is on.
    HI Ray
    If your music stops and you cannot see settings in the App, your network router is having an issue. Please check your Internet Router.
  • Rays Jazz
    Nothing wrong with the router, it is working fine. Would the blue light be on if the router was playing up?
  • Rays Jazz
    OK, powering off the iPad seems to have fixed it. Never happened before.
  • Rays Jazz
    The issue is back again, getting a bit tiresome, having to do this every few days.
