Network microcuts start optical-in automatically
BeantwortetWhen I have optical input connected, and I'm streaming from Tidal, when there's a connection problem, BluOS jumps to Optical Input sttoping the streaming. If I unplugged the Optical input, streaming goes perfect all the time. Is there a way to avoid this jump? (I'm thinking is a network problem what start this behavior, but could be other thing). Optical input is connected to a Xiaomi Mi Box TV, but is power off almost all the time.
I have a Node 2i
I would first test to see if disabling Auto Sense via Settings > Player > Customize Sources > Optical Input > Auto Sense in the BluOS app stops the issue from happening. If it does, your Xiaomi box might be sending occasional low level signals on the optical, or the optical cable's sensitivity may be high so swapping the cable out may also resolve the issue.
Thanks @Sam, this solve my issue. I will try to change the cable (is the official one that came with my node 2i) or maybe try to use a non optical one, because it's not so important quality from that box.
Thanks again
