Problem with multiple value in genre filed
6 Kommentare
    Hi Dimitry - when you enter
    Rock; Pop; Electro - this song will be filed under Rock; Pop; Electro when you filter by genre. When you search for any of Rock, Pop or Electro it will appear as a search result. this is pretty standard in any database.
  • Dmitry
    Ok, but how it it is in UI? I have the navigation point Genre. If i click on this I see the alle values. The problem ist, that if genre  has multiple semicolon values, the full value will be displayed.
    For example genre field has: Rock;Pop. And in UI unter genre I have only one value with Rock;Pop, And not one list.
    For this example, I have only three songs on usb. All id3 tags are exists. Genre has multiple values with delimiter ";". And they are not recognised as list, just as string
  • Dmitry
    the same problem is with  the "Composers".
  • Dmitry
    do someone read this and try to help?
    HI Dmitry - please see the official response here; https://support1.bluesound.com/hc/en-us/community/posts/4410606059671/comments/4410616730007
  • Dmitry
    Hi Tony, But it is not solve any problem...  Im am self Software developer and I don't understand why it is so har dot make normally delimiter splitting?
    Normaly if you have one field with genre, the you are clicking on it and see the values. If field value ist "Rock; Pop; Electro" then in the software I hope it must be listed as list? Or not?
    All Tag editors support this.
