Can I use two different models of Bluesound Node using same wifi network?
  • Josh L
    Alain, thanks for your reply. So Node 2 and Node 2i works fine  and can be grouped. That's good to know. I'm wondering if N100 will do the same.
    ALL BluoS Players are designed to work together, this includes the original NODE N100 playing nicely with our latest NODE N130 and N330 just released this spring.
  • Josh L
    Tony, thank you for confirming that.
