No power in Powernode N150
4 Kommentare
    HI Jacob
    I am so sorry to hear that - I have escalated your request to our Support Crew as they will be happy to provide options for you in your region.
  • jacobwod
    Thank you for quick action Tony, I've been contacted by the Support Crew and look forward to provide them with more detailed information!
  • Paul Huxley
    Hi there, I have been using a Powernode N150 since 2015. This morning it didn't appear on the app and a restart - power off and then back on again - didn't sort it. On close inspection, none of the lights are illuminating and I have tried changing the power lead. I'm guessing this is an internal hardware fault. Is it something that can be fixed?? Thanks.
    Hi Paul
    Please e-mail our Support Crew at support@bluesound.com with details including your geographic location so we can look at options specific to your region.
