Blusound Node2i using Big Sur on MacBook
BeantwortetHas anyone had this problem? When trying to index music on MacBook it appears that Apple now use a folder "Music" to store cds, not iTunes (which it use to prior to Catalina/Big Sur) when you try to index music on the Node the path is now iTunes - iTunes Media - Music - Music - then your cds! which is fine, but the next day when you try to play a cd off your music collection, a Error Notification appears saying Access Denied
If anyone has had this problem of if anyone uses the Node on a MacBook Pro with either Catalina/Big Sur OS i would love to know. Thanks
Hi Colks
Here is how to reset permissions on your MacBook - https://support.bluos.net/hc/en-us/articles/360000485508. Once completed, please select Help, Diagnostics, Rebuild Index to purge and reset your Local Library database.
If problems persist, Help, Send Support Request in the App.
