LED always on / Settings bug
7 Kommentare
    Hi Paul
    Can you please select Help, Send Support Request so we may take a closer look. We are having a hard time replicating the option not appearing.
  • Paul Francis
    Seen a few posts about the led being random on off, I've a new node and have switched of the led in the menu it remains off, the node is out of the way don't know  if that makes a difference.
  • George Chatzidakis
    There have been many complaints about the LED, in my case they say it is a defective product (I guess yours as well) and now they demand from me to pay 40 euros shipping costs to return it from where I bought it! Apparently, there is a batch of them.
    The worst thing though it is their customer care. It is one of the worst I have experienced!
  • Vandenhoed
    I have the same issue. When i switch the led of it goed of after the proximity timer expires but it goes on directly after again and that goes on and on.
    i know switched off the proximity feature but than you cannot switch off the blue led anymore. Only the options normal and dimm are possible. Even when i than switch om the proximity feature again the option front blue led option does not come back.
    seams a software issue to me
    Our QA and Engineering team is investigating an issue with the front LED pulsing on the NODE N130 in conjunction with the proximity sensor periodically being triggered by a false positive randomly turning it on such as light from a window or a plant in proximity then turning off at a regular interval - we hope to resolve this in software in a very near-future release.
  • Paul Francis
    I don't know if this is any help, I have had the intermittent blue light even though I've set it to off.
    This happens when connected by the analogue outputs to my power amp, but when connected to my dac by coaxial without any analogue connection the light stay stays off as per the off settings in the bluos app.
  • Permanently deleted user
    Do your engineers have any updates regarding this annoying issue?
