Node 2i no WiFi
BeantwortetI have been happily using my node 2i for a couple of months. A few days ago I got a pop up on the mobile app informing me that there was an update, did I want to accept the update? Of course. I was a little confused, was this a mobile app update or a firmware update? In any case I accepted. Afterwards my player no longer appeared in the mobile app (I have both iPhone and iPad versions, both lost the connection to the player.) The apps instruct me to go to settings and connect to the player via WiFi, but the player does not appear in the WiFi list. I rebooted the player, no change. My player is connected to my network via Ethernet. I tried controlling the player with the PC app, and that was successful, totally normal. Since I primarily use the mobile app to control the player I am keen to resolve this. Please advise.
Ah ha! I realized there was probably WiFi configuration in the PC app. Yep. Easily resolved.
