6 Kommentare
  • David
    Happens with BluOS app as well with above services...
  • Colin Saunders
    Me too.  Tidal via BluOS.  Node (3) straight into power amp.
  • Niko Hofbauer
    Is there a solution yet?
    Hi All - Update on this issue...
    We are continuing to investigate and hope to publish an update shortly but it appears to be happening when a sub-woofer is attached that the muting switch is not firing. Please continue to check back for updates... and thank you for your patience...
  • Luc Weytjens
    I have this same problem (touched upon in another thread), but there is no subwoofer involved here. In fact, it is a very straight setup, analog outs of the Node (N130) going to a pair of active speakers. No subwoofer, no external DAC.
  • Albert C
    My subwoofer has speaker level inputs, that was my work-around.
