Constant red light/unsuccessful factory reset Vault 2i
BeantwortetAttempts to factory reset have been unsuccessful. Constant red light. LAN port is orange and a hear a clicking sound about every 2-3 seconds. What should I do now?
If not already done so, use the BluOS App to log a support ticket, if you cannot do this then use email support@bluesound.com
Hey Clay. I have the same problem. Please let me know how you get this resolved. I will let you know what I hear also. Thanks !
