Détection automatique du signal de sortie
BeantwortetPouvoir switcher automatiquement ou manuellement la sortie coaxial numerique ou la sortie rca en fonction du dac que l on veut utiliser 1/ node streaming seulement connecté à un dac externe 2/ node comme streamer dac
Hi,
I understand that you would like the ability to easily switch between the NODE's digital coaxial output and RCA analog output, depending on whether you want to use an external DAC or the NODE's internal DAC.
I will pass your feedback along to our team for future consideration.
Thanks for #LivingHiFi
