Bluesound sub + connection problems to Cyrus 40 ST streamer
BeantwortetHi, I can see the sub+ in the players draw along with the Cyrus.
I can't seem to wireless connect the sub.- I have been told this is not possible?
If I connect via the analogue out , the sub indicator goes blue not flashing.
Might be a dumb question, but do I just expect that the sub only works this way and does that mean I can still use the core features of the sub i.e. crossover, etc
Hi Russel,
Wireless pairing of the PULSE SUB+ is not supported with the Cyrus device. As you are already aware, you can connect the PULSE SUB+ using the analogue subwoofer output from your Cyrus.
When connected via analogue, the PULSE SUB+ will operate as a conventional powered subwoofer rather than a wirelessly paired BluOS subwoofer. You can still adjust settings such as crossover and volume directly on the SUB+ to properly match it with your main speakers.
