Streaming drops on Node Nano with ethernet connections
4 Kommentare
    Seppi Evans
    See if it started around the same time Unifi sent out a firmware update - there has been many recent crappy ones. Next temporarily run a NANO use the Ethernet that’s currently on a CI 580 ( same switch, port and cable) and see if it still drops, Do also try a different source, local.music is a good option (few tracks on a usb memory stick plugged into the back of the NANO).
  • Joseph Oliver
    I streamed through one of the CI 580 devices for about three hours yesterday. It was flawless. I unplugged the ethernet cable from the back of that unit into one of Nodes (same switch, port, cable from the CI 580). The Nano played for about 40 minutes, then started the random drops again, about every other song for a few seconds. That is typically the way the drops occur ... it streams fine for 30 - 40 minutes then the drops begin and don't stop. I tried different streaming services and it doesn't make a difference. I bought the Nano sometime in May. I've had this problem from the beginning, hoping that a software update would correct it, but nothing has changed.
  • Seppi Evans
    Remove the NODEs from the UniFi console (delete their entries) and let them be discovered again, leave with default settings and test.
    Just a check you don’t have any WiFi BluOS devices do you?
    I actually pulled my UniFi router a good month ago after all the urgent security updates as for me stability was dire, so tricky to check settings without swapping the router out.
    At this point I would use the BluOS App to submit a support request immediately after its stops streaming. Support can look at the logs and advise further.
  • Joseph Oliver
    Thanks, I'll give that a try. I do not have any bluesound wifi devices. I have the pair of NAD's, two nano's, and one powernode. All are located in the same rack, connected to the same ubiquity switch using new factory made cat 6 ethernet cables. If your recommendation doesn't work then I'll follow up with support through the app.
