Low rumble when connected to SVS SB-1000 subwoofer.
BeantwortetI connected an SVS SB-1000 subwoofer to a Powernode N330 and there is a constant low volume rumble, sort of like tires rolling on asphalt. The rumble doesn't appear to increase when I turn the volume up - it seems to be a constant unchanging low volume background noise. I've tried swapping out the RCA cable between the two to no avail, and put both the Powernode & subwoofer on the same outlet (actually a power strip), and checked that the RCA cable and power cables are not running in parallel in an attempt to address a possible ground loop. I'm stymied. Any ideas on what to do next?
Hi Dennis,
I have escalated your feedback to a support request. A member of our support crew will reach out to you soon. -
Hi Mark, thanks for the escalation! I look forward to hearing from the support crew.
Quick and dirty; extension cord to another outlet on a different breaker for one then the other device then both. SVS has great Customer service, try them. Set up SVS with SVS app without 330 first.
-1
