Pulse Flex 2i no sound
BeantwortetI added a 2nd Pulse Flex 2i speaker but get no sound from the added speaker The speaker
displays a blue light and I can change tracks via this speaker so I know it's communication with the vault.
Also, what is the function of the 1,2,3,4 and 5 buttons?
Another user here… starting with the obvious, is the 2i selected in the BluOS App and the volume turned up. There are volume buttons on the 2i. The 1-5 button are for setting presets.
If this is second hand then it may be faulty or in need of a factory reset, if brand new (new old stock) I would contact the dealer directly.
If no joy use the BluOS app to log a support ticket.
