WiFi not connecting
    Seppi Evans
    If this is a new Router, then look at its web interface to see if there is an option called “client isolation” turned on. Might be a similar sounding setting.
    You don’t say what make of phone but In the iOS Settings, ensure under Apps that Local Network support is enabled for the BluOS App. In Android there is a similar setting,
