Subwoofer integration
    Mark T.
    Sr. Support Crew Member
    Hi Tamas,
    For Dirac to correctly calibrate your room, the subwoofer must be connected to the NODE.
    For 1:1 support please feel free to reach out to our support by sending us a support request using the BluOS app or sending us an email to support@bluesound.com
  • Ronald Howlett
    So I have a SVS SB2000 Subwoofer and I have been going back and forth between the sub-out on the Bluesound Node and my Yamaha RN2000A which has a sub-out.  While it is nice to use the sub-out on the NODE the volume on the SVS sub can only go up two or three notches, then,  BAM it really starts "booming" .  It is not the same intervals when I use the Yamaha sub-out, which i can go up very evenly in turning of the volume output.   Really don't understand why this happens.  Can anyone explain why this might be the case.  It is really nice being able to use the Bluesound Node crossover adjustments but at the expense of not having gradual volume adjustments to my subwoofer volume.   Any ideas out there?
