Spotify Connect doesn't work after latest upgrade
4 Kommentare
    Seppi Evans
    Next time try rebooting your Router and see if that helps, if the issue continues please email NAD for support of your NAD M66 support@nadelectronics.com
  • Mateusz
    Seppi, thank you for responding but we both know that rebooting the router is not the solution here.
  • Seppi Evans
    Try it, would have taken just as long as your reply 😁
  • Mateusz
    I just explained to you what's the fix so it follows (for people that "know computers") that restarting router won't help.
