TV-> Node (N132) -> Naim Superuniti: Advice on HDMI ARC vs. Optical; & Volume Control
    Mark T.
    Sr. Support Crew Member
    Hi Branon,
    Using HDMI ARC, the TV will usually switch audio away from its internal speakers and send sound to the NODE. Some TVs allow you to switch back to the TV speakers, but this depends on the TV and CEC settings.
    For a stereo setup, HDMI ARC does not sound better than optical. ARC mainly adds convenience features.
    Both coax and optical will work well between the NODE and the third party amplifier . It really depends with your preference.
    This can be done but you will have to set your third party amplifier to the max or higher volume which is not ideal.
    Hope this helps. If you need 1:1 assistance, please reach out to us by email at support@bluesound.com and we are here to help you.
    Thanks for #LivingHiFi
  • Branon
    Thank you for the very helpful reply.
