Burbling sound from subwoofer
    Mark T.
    Sr. Support Crew Member
    Hi,
    I see that you have submitted a support request with us in regards to this. Please continue working with us to get this issue resolved.
  • Christophe Macé
    Hi, same issue on my side.
    I bought powernode 2i in 2021.
    Everything was fine until last month.
    I'm currently experiencing issues about my powernode 2i and my sub using LFE input.
    When the powernode goes stand by mode, after a certain time the Subwoofer starts to make noise, quite high, a constant noise, like white noise. I've seen that this appears when the Tidal input is selected. Once I change input to HDMI or Radio, the white noise disappears. If I let the powernode with HDMI or Radio input selected, I've not this issue even in standby mode. I'm getting an issue only when Tidal input is selected. Can you explain to me what is the solution to fix it ? What happened regarding the signal path for the sub between Tidal input, Radio or HDMI input ? hardware changes or it's only a software modification ?
    Thanks for your help
