Solid red
    Mark T.
    Sr. Support Crew Member
    Hi Timothy,
    Please reach out to our support crew by sending us an email at support@bluesound.com and a member of our support crew will be happy to assist you further.
  • Oluwafemi
    A solid red light on the Bluesound Node 2i usually points to a failed update or network hang, not bad capacitors. A full power cycle and network reset often clears it, but if it keeps returning after reconnecting, support needs to reflash it on their end. Emailing them is the right next step.
