Using a preamplifer with bluesound network hub - any issues / problems
    Mark T.
    Sr. Support Crew Member
    Hi Sueaqg,
    Apologies for the delay in getting back to you. Your idea should work. Adding a third party preamp with physical buttons and a volume knob will make the system easier for everyone to use. While it does add another layer, it shouldn’t be an issue as long as the volume is mainly controlled from the preamp.
    One thing to keep in mind is that the POWERNODE volume would need to be set quite high most of the time.
    For more guidance on this setup, we recommend reaching out to your local dealer, who can help you with the final configuration. To check closest dealer to you, please click on this link below.
    https://www.bluesound.com/stores/
