    Permanently deleted user
    Hotspot mode is temporary only for setting up a WiFi connection, once done the hotspot WiFi will no longer be available and switches to the configured Wi-Fi
    You can configure Wi-Fi by using an Ethernet lead, once connected use the BluOS app to put in your credentials. Reboot and remove Ethernet lead. Temporary move NODE to router if you don’t have a long Ethernet lead
