Problem using Spotify connect with node nano
4 Kommentare
    Mark T.
    Sr. Support Crew Member
    Hi Remi,
    I see that you have an open support request in regards to this. Please continue working with our support crew member to get your issue resolved.
  • Remi Wjuniski
    Ok I wrote them.
    For info I was this morning at my hifi shop and ALL the node device (nano, node ,etc.. connected to a very fast internet via wifi or ethernet ) were having the same exact bugs with Spotify lossless as I’m experiencing. Hence it’s a software problem with Spotify lossless that you guys need to fix via a firmware update.
    The bug is only with Spotify lossless as described above (Spotify “very high” quality don’t have the bugs .
  • Remi Wjuniski
    I’m still waiting for the support crew to call me and answer my mail, I only have today to help them, next week I’ll be at work all day.
    Can you tell them to answer fast? Thanks :)
  • Karsten Degn
    My Bluesound now only works via Airplay and no longer via WiFi. This is really annoying and I have spend a lot of time troubleshooting, reinstalling and testing. Now more frustrating and no solution
