NAD C658 on Ethernet how do I switch to WiFi?
6 Kommentare
    Hi Robert
    Please see www.bluesound.com/setup as this will work for all BluOS Players including the NAD C658 - try Manual Setup using a Browser if the app is giving you problems.
  • Robert Cressey
    NAD streamer... not bad
  • Robert Cressey
    Thanks Tony..
    But like i said: "I’ve found the instructions for connecting to WiFi: add new player.. etc.. but it doesn’t work"
    I've tried on an Android.. On an iOS device... Manual: "This site cant be reached"
    So need some actual support.
    Thanks.
    R
  • Sam R.
    Hello Rob,
    If your C658 is still connected online with the Ethernet, reach out to our support crew using Help > Send Support Request.
    Otherwise, please send them an email at support@bluesound.com.
  • A.Derksen
    Hi Robert,
    I Had the same issue and i fixed is by accessing the C658 at the ip-address through ethernet and did the set up for wifi.
    After that i removed the ethernetcable and power cycled the C658. ( AC dosconnect and reconnect)
    When a lan cable is detected the device automaticly switches the wifi down.
    Hope you can fix  this fixed this way.
    regards,
    Arjan
    You can also select Settings, Player, Wi-Fi in the BluOS App
