    Kristofer Hadodo
    Lossless
    I am playing MQA via Tidal Connect to my Powernode gen 1 (N150) as I write this. Make sure your gen 1 players are updated to BluOS 3.12.2 and try again.
    Best, KriHad
  • Jorgen
    I have a PowerNode 150 - and it doesn't show up when I click on Tidal Connect - so I think you will need the second generation....
  • Jorgen
    Hi KridHad - thanks for your help - i had updated to 3.12.2 - and I still cant choose my PowerNode on my uPhone - but thanks to your reply I tried my old iPad, and from that I could connect from Tidal - my guess is that my iPhone will be able to connect some day - maybe after a software update..... I dont know if it is a bug on my iPad - but using the buttons for volume only mute/unnute  the sound - I cant adjust the volume
