Spotify : How to get the best sound quality?
BeantwortetHi all,
Just bought a Powernode 2i and I'm really happy so far. (on Monitor audio silver 100)
Everything worked in 5 min, which is really nice, but I'm wondering if I'm using correctly Spotify. I've launch the Bluos App (iOS), and just "press" on the Spotify Icon, which automatically launched the Spotify app.
From know I just have to use the Spotify App and select my Bluesound Device, that's all? And one last question, should I use the maximum quality setting from Spotify App (around 320k) or it doesn't matter?
Thanks in advance,
Best.
Simon
Hi Simon
When using Bluesound, always go for the maximum resolution available... in Spotify's case set it to 320K.
