TV Audio Problems thru Pulse Flex 2i
    Hello Wade,
    I'm assuming you have the players in a Home Theatre Group. I would recommend double checking your Video Source's (that may be your TV/Cable Box/Apple TV) settings to ensure the audio is set to Dolby on your Video Source Devices (perhaps un-setting this then re-setting would do the trick).
     Ungrouping and re-grouping the HT Group may also help.
    If you find you still have the static in your rear Flexes, please send our support crew a diagnostic log via the app under Help > Send Support Request (log will be automatically attached) so they may look into the issue further.
  • Wade McLaurin
    Hey thanks Sam.   I'll check those settings and see if that helps.
