Node 2i for home theatre w/ 2 active speakers
BeantwortetHi!
Looking for a new connected preamp for my Gelenec G Threes and the Node 2i is top of the list - if I want to add the Pulse Sub+ (and maybe Flex 2i’s as back channels too) later, will the Node 2i work fine for home theatre playback? Delay etc?
As the current speakers are active, can’t use the powernode.
Hi Jami
The NODE 2i does not support Home Theatre Grouping nor does it support DOLBY decode. Sorry you will have to look at a POWERNODE or PULSE SOUNDBAR for your needs.
