Powernode 2i-HDMI randomly switches to HDMI input
81 Kommentare
  • Przemysław Giera
    Was the issue addressed finally? I have the same problem with my NAD C700 & SONY KD-55XG9505
  • Dave Chawner
    I don't think it ever has been fixed.....I live with a workaround, not very satisfactory, but needs must!
  • Przemysław Giera
    It is sad! I spent lot of money for hifi with HDMI as must have and it is not working as expected.
  • Dave Chawner
    Hi Przemyslaw,
    I totally sympathise with you, it's all rather frustrating!
    Sony TVs, amongst others also maybe, appears to send various commands to external devices via the HDMI ARC connection, even when the TV is in standby. The problem is, the Bluesound products seem unable to filter out which of these commands BluOS should respond to and which they should ignore.
    I would have hoped that Bluesound product managers would have long ago had discussions with Sony TV product managers in Japan to work out a way to resolve this issue.......but they don't seem willing or able!
    By the way, I used to work for Sony Europe and feel sure Sony would have cooperated, if asked.
    Maybe you could raise the issue with Bluesound once again?
    Regards.
  • Przemysław Giera
    Thanks Dave for your answer. I already created a ticket for NAD support. Let's see what they will reply.
  • Kerimike42
    Hi
    I suggest you use the work around I posted above. It works some months later. I also used NAD support including log files to no avail.
    Best of luck
  • Tomas Jurik
    Right, so after having read this post and a bunch of others, the conclusion is that neither Sony nor Bluesound are willing / able to fix this issue that's clearly plaguing dozens of users.
    Bluesound's suggestion is to turn off CEC "and use IR programming for control". Great advice in 2022, when the majority of TV remotes are actually Bluetooth and when CEC has been around for over a decade. SMH.
    Given that I bought the Node 3 online (picked it up today), I will be returning it tomorrow, likely marking it one of the shortest ownerships of the product ever. I have to say that simply because of this the Node 3 is by far the biggest disappointment of my entire Hi-Fi journey.
    Maybe Bluesound could consider getting their heads out of their butt and actually do something about this, considering this issues was first reported over 2 years ago?
  • Dave Chawner
    Tomas, very well said!!!
  • Kim Dumont
    I didn't have this problem when I bought my powernode 8 months ago, but it has become increasingly unbearable the last few months. I feel like a simple solution would be to include an option where autosense only switches the input after 2 seconds of continuous input. But reading the replies here it seems that Bluesound is content with blaming another company, instead of putting some effort in solving this issue for their customers who bought an expensive product with an issue that defeats its whole purpose.
  • Dave Chawner
    Totally agree!
    Also, for what it's worth, I have had occasional problems with the HDMI link between my Sony TV and the Powernode locking up, such that even restarting both the TV and the Powernode won't resolve it. I have now discovered that clearing the Play Queue with the HDMI source selected in Bluesound app appears to restore the HDMI link. This is hard to prove since the total HDMI lock up occurs rarely. I believe there are bugs in the BluOS that Bluesound can't or won't address.
    Hi David
    Your diagnosis 6 months ago here was spot on; https://support1.bluesound.com/hc/en-us/community/posts/360051665254/comments/8311361777687
    There are a number of things SONY appears to do with HDMI CEC that slightly vary from industry standards. Have you contacted SONY about this issue since your post and based on our experience with similar consumer issues we and our good friends at NAD Electronics have also seen in their AVR platform is the root of the problem you and other SONY TV users are seeing with CEC.
    -1
  • Dave Chawner
    With respect, I am a customer, you are a product support manager........it is your job to interface with another manufacturer, in this case Sony, about interconnectivity issues between products from both companies, Bluesound and Sony!
    I may well have worked for Sony in the past, but I am retired now. Your are much more likely to gain the attention of Sony product management, being an Audio HiFi manufacturer, than I am as an individual consumer.
    Please try harder to get to the root of this problem area and hopefully solve it!
    Hi Dave
    As a fellow consumer, I would be angry and frustrated too, but unfortunately, with the problem you are having, I cannot help you with as much as I would like to.
    I would be happy to clarify. Bluesound and its parent company work hard to ensure we are following industry standards for cross-brand interfaces by most other industry-leading manufacturers. Based on the feedback you have provided, and our own testing, we have determined the root cause of your problem is in your SONY TV your own troubleshooting confirms this.
    We encourage you to continue to work with SONY to resolve the issue with your product and hold them to the same standards.
    Thanks for understanding.
  • Laurent EVRARD
    I have the same problem, with two different Sony TVs (65XK9505 and 65X94K) and with a NAD M10 and a NAD M10 v2.
    When you turn off the TV, it mutes the NAD. And 1 time out of 3, when the TV is turned on again, the NAD remains on mute, or does not turn on.
    When we look at the logs, we see that the Sony TV keeps sending CEC information.
    On the other hand, I can listen to another source for hours, I have no interference and the sound does not cut out.
    Feb 28 21:53:49 (none) user.info sovi-arc: eARC discovery timeout
    Feb 28 21:53:49 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:50 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:51 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:52 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:53 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:54 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:55 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:56 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:57 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:58 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:53:59 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:00 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:01 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:02 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:03 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:04 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:05 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:06 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:07 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:08 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:09 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:10 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:11 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:12 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:13 (none) user.info sovi-arc: CEC send Initiate ARC
    Feb 28 21:54:13 (none) user.info sovi-arc: CEC TV requested ARC initiation
  • Carlo Di Martino
    Yes. Frustrating as this is as far as I know, it is only affecting Sony TV owners and I know from experience that similar problems with Sony TVs occur with Sonos products as well. It's always Sony TVs. No other brands that I know of so it's Sony's problem not Bluesound's. It's the main reason I would not purchase a Sony TV.
  • Rico Yao
    I just picked up a new Sony TV (Bravia 7) and started running into this.
    One pattern I’ve observed is that when the problem happens, the blu app was showing that hdmi is playing something (with no actual sound, but the time indicator is incrementing). Sometimes it shows as a multi-hour session. If I “pause” that phantom hdmi playback before initiating music from another source, then I won’t be interrupted by the Sony TV.
    My suggestions:
    - Add an option to have the powernode automatically send a pause command to the prior hdmi source before playback from another source starts. I know your devs will hate adding special cases like this, but perhaps this is a decent compromise so us Sony TV owners don’t get stranded.
    - Add an option to let us disable auto sense for a certain amount of time. That way I don’t have to remember to re-enable autosense after listening to music. Have a popup show in the app if you detect the user switching back to music source again after hdmi takes control.
  • Dave Chawner
    Hello Rico, when I last commented on this problem, I noted that Bluesound wanted myself, a Bluesound customer, to take this up with Sony. This is crazy! It's Bluesound's responsibility to take up interoperability issues with another vendor, in this case Sony. This is the job of a company's Product Manager.....I know because I used to be one with Sony Broadcast Europe!
    Maybe you can have more luck with getting Bluesound to get on the phone to Sony TV's Product Management!!!
  • Przemysław Giera
    Due to this I changed my amp to other brand and never come back to NAD…
    2
    Hi Rico
    Asked and Answred here; https://support1.bluesound.com/hc/en-us/community/posts/360051665254/comments/12753676925335
    Here; https://support1.bluesound.com/hc/en-us/community/posts/360051665254/comments/12753676925335
    and Here; https://support1.bluesound.com/hc/en-us/community/posts/360051665254/comments/12766128024727
    Please consult your SONY TV Documentation on how to disable partial standby and use full standby to turn off the HDMI port. It will vary from SONY model to SONY model and is usually 4 or 5 menus deep.
    -2
  • Rico Yao
    Hey Tony,
    I saw those threads. These options don’t exist on the latest Sony TVs it seems.
  • Kerimike42
    I had this same issue with my Sony A9f. I found a solution which I posted here. Was surprised to get the email and see even latest Sony has the issue however it is not alone. 18 months ago I got a Panasonic LZ2000 77. Guess what similar problems. I wall mounted the tv and ran hdmi extension leads. Randomly the tv would revert to the internal speaker. After a while I discovered that pulling the amp hdmi cable from the extension hdmi solved the problem. A few weeks ago there was a software update that fixed stability issues. Touch wood I have had no further issues.(including random display resolutions from my firestick). Both tvs had different operating systems. One commonality seems to be Mediatec. Don't hear about Samsung and LG with this issue for what it's worth.
    Mike
