Node 2 forgets volume setting
    Hi Wouter
    We will need to take a closer look here to see what changed in your setup. Can you please select Help, Send Support Request so we may review the System Event Log of the NODE. Thanks
  • Wouter Linckens
    Thanks for the reply. I had this problem for a few days and today it worked without issues. If it reoccurs, I will contact the support desk via the app.
