NAD c368 as preamp with subwoofer
    Hello Kris,
    Unfortunately as the PRE OUT and SUBW OUT on the C368 is a shared connection, this would not be possible without some likely-undesirable workaround (line splitter cable).
  • Kris Broodcoorens
    Thank you for the information. That is a pity.
    In case of a line splitter cable, will this influence the sound quality or even worse: damage the hardware?
