Changing default behavior re repeating queue
BeantwortetI recently replaced a dead/bricked Node2 with a new Node 2i... it's working fine except I seem to recall with the Node2 that there was a global setting which set queue repeat to OFF - in any event the old Node 2 didn't repeat queues, nor does the other one that I have in a different location. I know where to change this in the Playing Now window with the 2i but is there a setting where I can turn the repeat behavior OFF permanently?
Thanks!!
Hello Robert,
Not 100% sure which would be the culprit in this case, but you'll either want to check Settings > Playback > Autofill OFF, or opening the Now Playing screen (the screen showing what's playing, with the Next/Pause/Previous buttons; you may need to maximize the window if using the desktop app) and making sure that loop icon is grey.
