Home Theatre rear speaker disconnecting
    Hi Dave
    Two suggestions - If it fell out of the Group and appears separately - your entire system lost power and rebooted. The FLEX in question finished rebooting before the POWERNODE - simply reboot the FLEX and it should correct itself.
    OR
    If it is still part of the group but not playing, then it is not receiving packets timely. Check it's wireless signal strength using our network troubleshooting tips at www.bluesound.com/network101
  • Dave Chawner
    Many thanks for your suggestions.
    What I have done already a couple of days ago is a factory reset of the Flex and a fresh reconfiguration of my theatre group.
    Will now monitor to see if the problem repeats.
    By the way, I recently posed another question about theatre groups…..what is the effect of the “speaker distance” settings config page, as there is a separate config page anyway for sound level settings?
    Many thanks.
