How to run presets in Nad C658 using the SR9 remote control
BeantwortetHello
I recently purchased a NAD C658. Unfortunately, its SR9 remote control dosn`t run presets, nor can they be programmed in the app. I bought a RC1 remote that allows to run presets in NAD. Is it possible using SR9 ?
Thanks
Hello Jacek,
Unfortunately as there are no IR capabilities for BluOS presets on the C658, it would not be possible to program these presets to the SR 9 at this time.
Sam R. -
Hello Sam,
Thank you for your response.
But then I have a question: why?
In another room I have Powernode 2 - I can program the remote, including presets.In C658 I can program remote for BluOs - Play / Pause / Down / Up .... :) but not presets :(
IR remote RC1 allows to run presets in NAD.
Why not SR 9 ?
Is it a technical, software or other problem?
Is such functionality planned in the future?Regards,
Jacek M.
