Bluesound vault 2 with Roon: shared network
3 Personen folgen
6 Kommentare
    Hello Antoine,
    Roon and the Roon forums might be able to help you a little better with this, but from what I understand with Roon it treats the Vault as a NAS (which it technically is).
    So you should be able to point to the Vault's contents/ripped CDs as a Network Share, using the \\IP_ADDRESS\Music path (if a username is needed, use Guest (no password) ).
  • antoine mazurie
    Thanks! This is exactly the information I was looking for.
  • antoine mazurie
    I have tried with my IP address (IPv4) but it doesn't work. Any idea of what I could miss?
  • Sam R.
    Are you using the IP Address for the Vault from under Help > Diagnostics in the BluOS app?
  • antoine mazurie
    Thanks, it works perfectly!
  • Davoren Chick
    I appreciate this explanation. It took me a while to find it though, using up a full week of my free trial. It would be great if there was a true user's guide that walked you through this, without all the jargon. I'm fairly tech savvy  but I have found this audio setup has required more sleuthing than expected.
